71 Chevelle oil dip stick tube problem!
I was installing headers on a 71 Chevelle and the dip stick tube was in the way, so i tried to take it out of the block and it snapped off right at the edge of the block! What would be a good way to get the rest of the tube out? Ant help is appreciated. Mike
On many blocks they are pressed in with a length of tube extending inside the block. If this is the case it will not pull out. You will need to drill the old one out which leave the filings and the section of tube in the pan. Get the new tube and take a look at it or find a block similar you yours that you can look at, this will tell you what you will need to do. If it is just flush to the block on both sides, you should be able to drill, chnge the oil, and you should be OK.
That happened to me with my 302. I used a self-treading machine bolt that was a little larger then the hole, ran it in and then pulled it out with a vise grip. No problem. No metal shavings.
