no spark! help :(
no spark! help :(
Bought a 98 C5 coupe. Dropped an iron block 6liter in her.
Im using the truck coils. And just replaced The crank and cam sensor. Still no spark.
Passenger side and driver side and rear block grounds are hooked up.
Testes the coil plug. 12v on 1st pin, and ground on both 3 and 4 pin. 2nd pin is supposed to be signal.
I think thats my problem. Im not getting signal to the coils to tell them to fire.... what should I check next?
