When putting in a motor from the top is it easier too.....
I need to know if I should go ahead and bolt up the top half of the motor mounts to the motor and try to set the motor onto the complete mount and bolt up the 4 bolts on each side after it is in position, or if I should bolt the motor mounts onto the engine and then try and sit them onto the lower half of the mount already connected to the K member and then tighten the two main bolts?
Shorty Director
Originally Posted by onyxxtreme
I'de bolt lower the engine in, with the mounts already bolted on, and just slide in the 2 long bolts when aligned up- 1 side at a time
been hella easier to me
