LS1 valve cover on LS3 heads
Old 05-20-2014, 11:59 PM
gomezmk's Avatar
Default LS1 valve cover on LS3 heads
I have a LQ9 with LS3 cylinder heads. I got a pair of LS1 valve covers and noticed the passenger side baffle hits the off set rocker arms. So I removed the baffle and clearanced the valve cover to clear the rock arms. Now I'm trying to figure out if I should run a oil catch can for the PCV system. I have the stock valley pan cover with NO vent. I'm also running a carbureted manifold. Anybody have a diagram for a oil catch can set up? Vented or non vented can?
Old 05-21-2014, 06:15 PM
Hardcoresoldier's Avatar
yes. cap off the PCV ports on the cover and draw crankcase vacuum from the valley cover.
I too found out the hard way I had to cut the baffles out lol.
Old 05-21-2014, 11:14 PM
gomezmk's Avatar
I currently have the stock valley cover with no vacuum port. Is there another way to route the hoses from the valve covers to a oil canister?
Quick Reply: LS1 valve cover on LS3 heads
