LS1 to 5.3 conversion help
I recently did an LS1 conversion in my 1971 chevy C-10 and got about 30 miles out of it before it started knocking ,so I pulled it down and it was the worst case senatorial, spun rod and spun main ,when I got further into it the block was cracked on the main journal..
So I just picked up a 2003 5.3 with 83K on it ,I want to use the new PSI harness and PCM I just installed for the LS1,, my plan convert the truck intake to drive by cable and hopeing to use the LS1 injectors on the truck intake with my LS1 mass air..can you all see any for see able problems,,,,thanks ahead for any response Jim
Why do you want to use the truck intake instead of the ls1 intake? If you have a fuel injected LS1 the easiest swap would be to just switch everything from the LS1 to the 5.3 just use the long block from the 5.3 and use your intake/oil pan/drive accessories from the LS1.
