New motor running rough
So just got done putting in an LQ4 this past week. Car runs, but it's pig rich (10 MPG max), surges, idles rough, kr up to 9 at light throttle, and will stall occasionally. I just now noticed on my scanner that my MAP sensor is constantly reading 3.1 inHG; from idle to throttle. The shop put a "start-up" tune on it to break in the motor before it goes on the rollers. Would a bad MAP sensor cause all these issues? Or could it just be a crap tune?
Its also throwing a
P0101- Mass or Volume Air Flow Circuit Range/ Performance Problem
P0507- Idle Control System RPM higher than expected
Thanks
Its also throwing a
Thanks
Sorry mate, but once again I can't believe the mindset of some. Is it just a US thing due to the way you treat the Dyno.
Here any mods that will affect the tune, the car goes on the Dyno straight away so the tuner can do his thing.
No mail order tunes or something temporary, we get the car on the Dyno, no ifs or buts.
Would have been nice but hasn't seen any actual logging besides my scanner. It'll be on the dyno next week so I guess I'll just take it easy till then.
