PS pump mounting location
OK Guys! Need your help here!
If you look at the pic, the idler and the PS pulley are close together. I can't even fit the belts under there without rubbing it in. IM using aftermarket ebay bracket for the pump and fbody alternator bracket. Is the idler pulley suppose to turn or is it immovable?
Im also using a stock ps pulley.
Help.
Help.
