Looking to squeeze last bit of power
Tune is scheduled for Feb 28, mods are listed below, 02 Camaro SS 6 spd. I am looking to squeeze the last bit of power out of the car I can, maybe something I overlooked? Not looking to change heads/intake yet. I am pretty much done with this motor, as I plan to use it as a donor for my 96 TA and build a 370 for the 02 later this year.
Only options I see are UD pulley and spray. I am not 100% sold on a UD pulley, have been looking at Powerbond, and to do a kit the right way(FPSS, Window Switch, Heater, Purge, etc..), price isn't in the budget at this exact moment in time. Give me some thoughts. Thanks
Tick SNS 3
.660 Valve Springs
Ported LS6 oil pump
BTR Trunion Upgrade
LS2 chain
Katech LS6 Damper
Ported TB
Ported/Descreened MAF
LS6 Intake
Blackwing Lid
FLP Long tubes
2.5" X-pipe
Racetronix 255 with hotwire
FAST 36 lb injectors
TB Bypass
Diamond Stage 1 clutch/flywheel
Tick ADJ master cylinder
MGW shifter
4.10 gears
Norris catch can
Stock thermostat
Thats all I can think of at the moment
Tick SNS 3
.660 Valve Springs
Ported LS6 oil pump
BTR Trunion Upgrade
LS2 chain
Katech LS6 Damper
Ported TB
LS6 Intake
Blackwing Lid
FLP Long tubes
2.5" X-pipe
TB Bypass
MGW shifter
4.10 gears
Norris catch can
Stock thermostat
Tick SNS 3
.660 Valve Springs
Ported LS6 oil pump
BTR Trunion Upgrade
LS2 chain
Katech LS6 Damper
Ported TB
LS6 Intake
Blackwing Lid
FLP Long tubes
2.5" X-pipe
TB Bypass
MGW shifter
4.10 gears
Norris catch can
Stock thermostat
Tick SNS 3
.660 Valve Springs
Ported LS6 oil pump
BTR Trunion Upgrade
LS2 chain
Katech LS6 Damper
Ported TB
LS6 Intake
Blackwing Lid
FLP Long tubes
2.5" X-pipe
TB Bypass
MGW shifter
4.10 gears
Norris catch can
Stock thermostat
25% UDP
3" X pipe exhaust
160 thermostat
chrs1313/ssra/ftra ram air
150 shot
Do the headers have a 3" collector? Are they 1 7/8"? If not, upgrade to those specs along with the 3" exhaust.
- Drew
