rough idle/low oil pressure
my car has acted a little odd the past two days, every now and then it will idle a little rough while in drive, and yesterday at idle while the car was in drive the oil pressure dropped below 40 almost to 30 psi which to me is alarming (I'm pretty sure that's really low) if I put the car in neutral the pressure goes back up pretty even to 40 psi and the rough idle goes away
anyone have ideas on what this could be, I know it could probably be a million things but I just want advice on what to check before I take it to a shop and they charge me 100 bucks just to tell me something is wrong
My guess is when it's in drive and idling ruff the RPMs are lower than when it wasn't running ruff. Lower RPMs means lower oil pressure. That also explains why putting it in neutral (rpms go up) The oil pressure goes up. Find the reason for the rough idle and fix it and the oil pressure will hold steady like it used to.
