Throttel body and intake set up on 03 silverado
Hi I'm new to the whole motor modifying thing and so I thought I'd ask a few questions.
I've got a 2003 Chevy Silverado 1500 with the 5.3. I've been looking at the edelbrock pro flow xt intake and would also like to put on a 95mm Holley throttle body. But I keep reading that the 03 and up Chevys have some type of electronic throttle body. And so I'm not sure if that throttle body would work.......Please help 😁
Thanks in advance!
Thanks in advance!
You'll have better luck getting user feedback on performancetrucks.net. It mainly depends on your goals. If you're planning internal mods down the road, go big on the intake. The FAST truck intakes are excellent and, if you've got the coin, that will likely be your best option. As for throttle bodies, there is either drive by cable or drive by wire. I'm not sure which year they changed that, but look at your stock one. The difference is obvious. Order whichever one matches yours, but not before researching your options very thoroughly. Good luck.
