Old 05-09-2016, 12:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Air Intake and Exhaust Guides
Print Wikipost
Review and install guide for the MSD Atomic AirForce intake manifold.
Old 08-09-2015, 02:00 PM
  #201
lq4240sx's Avatar
Originally Posted by GetItAt_will
Yea that's the part number I need. I told them the first time I ordered that I needed it for a stock LS throttle cable and I guess I got the one for an aftermarket cable. Sad thing is the one I need 2707 isn't in stock and I was told there was not ETA I was told to call back in 3 weeks.......................... This bracket is all I'm missing so now I can drive the car or tune it until I get that. I'm really disappointed with the setbacks I've had with this thing. I definitely regret not going with the FAST 102 instead lol
I made my own throttle cable bracket
Old 08-09-2015, 05:30 PM
  #202
GetItAt_will's Avatar
Honestly I just decided to do that as well after the out of stock incident. I'm going to take the bracket from my stock LS1 intake and fab it to the MSD bracket I got. I did get her started today for the first time. Seems like every time is good so far but I won't know until I get it on the road to really drive and get it tuned.
Old 08-10-2015, 07:00 AM
  #203
lq4240sx's Avatar
Yeah it looks kinda trashy but paint it black and hidden behind all the vacuum lines and you can't even see it
Old 08-10-2015, 09:36 AM
  #204
98cherrySS's Avatar
For the amount of money people are spending on this MSD intake, there should be ZERO issues. Three weeks for a bracket? The intake shouldn't have been announced without adequate stock of all necessary hardware for all possible configurations. Thank you for sharing your experience lq4240 and sorry for your troubles. You deserve better considering your investment.
Old 08-10-2015, 09:56 AM
  #205
redbird555's Avatar
The scale on just how big MSD dropped the ball on this is embarrassing.
Injector bosses not drilled.
Intakes not sealing
No Hardware included.
Hardware needed unavailable
Most of all it doesnt live up to the glory claims MSD was making
Old 08-10-2015, 08:38 PM
  #206
lq4240sx's Avatar
Oh yeah I had to reuse the bolts off the ls6 intake I had to bolt it down. I mentioned this to my tuner and he said "I just tuned one of those for a guy that has a c5 zo6. The difference between the ls6 and the msd was 1hp..."
I'm still waiting on dyno time but I will update you guys as soon as I get on there with my numbers.
Old 08-11-2015, 12:16 PM
  #207
98RedZone's Avatar
I'm not sure if its the same article as before, but read an article on Facebook today where LMR made 30 hp with a MSD over a stock LS7 intake. The Z06 was lightly modded.
http://www.superchevy.com/how-to/eng...pr=26824546950
Old 08-11-2015, 07:07 PM
  #208
UNDER PRESSURE MOD
The Alchemist's Avatar
Very interesting. I wonder how much of a difference having the better flowing heads and different runner design of the ls7 vs the ls1/6 catherdral ports makes with the power gains.
Old 11-27-2015, 02:52 PM
  #209
neverstop's Avatar
anyone tested one of these on a >650whp boosted setup yet? I'm curious on the reliability and gains over a stock ls7 intake setup. I'm fine with my current ls7 intake but if this offers good gains and does not have the issues the FAST has in boosted applications then could be interested
Old 11-27-2015, 07:53 PM
  #210
UNDER PRESSURE MOD
I did... made 862/760 but was spinning with a very fat tune and no timing in it. So there was no need to add more timing or lean it out on the dyno since it wasn't holding.
Here's the snapshot of the data log. See, afr was 10.5 and timing was only 14.5 degrees. There was a lot left in the tune, just no point in making more pulls when the tires kept letting go at 4000 rpm.
Old 12-18-2015, 09:56 PM
  #211
LSwonderfull's Avatar
Default MSD vs LS6
I have back to backed my LS1 with both intakes and I see 25 hp based on mph at the track with the MSD and 102mm tb over LS6 with 85mm tb. My car runs in the 10.90@124 mph range with a lq9 headed large cammed 5.7'
I turn 7600 clean but the map is at 98 thru the traps so the plenum is restrictive on both intakes. Here the baro is high and map koeo is 103 at times. I do have a surge issue and have yet to find where the leak is. I replaced all the gaskets compliments of MSD still surges.
Old 12-19-2015, 09:35 AM
  #212
UNDER PRESSURE MOD
My car idles perfect at 650 these days with no surging. Sure it still has some issues returing to idle every once and a while, and cold starts are still not quite 100%, but considering it's a 416, with an f1a, and a decent size cam, I'm pretty happy.
I pressure tested my intake tract up to ~20psi and the only leak I have is from the throttle body shaft seal. Try doing that to see if you can find your leak.
Old 12-19-2015, 09:49 AM
  #213
UNDER PRESSURE MOD
Old 05-24-2016, 06:57 AM
  #214
samerickson89's Avatar
What did you end up doing about the water vent lines? Did you mod the existing ones or replace them?
Old 05-24-2016, 03:56 PM
  #215
UNDER PRESSURE MOD
I replaced them. I connected the rear two together, and then connected the front 2 together, and returned them to the radiator.
Old 05-24-2016, 09:20 PM
  #216
Cool, I'll see if I can figure out how to do the same. Thanks!
Old 05-27-2016, 03:41 PM
  #217
So I got a hold of tech support and asked for the dimensions of the hardware in their adapter kit for using LS1 injectors with LS2 rails, and they said the o-rings are 4.31x7mm. Closest thing I've been able to find is 4.1x7.1, think that small of a difference would be a problem? I'm thinking being a tighter fit both on the ID and the OD might help since people are saying they have trouble getting them to seal properly, but I thought maybe someone on here would be able to say with a little more certainty. Thoughts?
Old 05-29-2016, 05:42 PM
  #218
Have any good pictures of it? I wanna do the same thing, but I figured before I just wing it I'd see how other people did it.
Old 10-04-2016, 06:38 AM
  #219
So the instructions say there are a screw and washer provided to mount the MAP sensor, but a) there's no hole on the MAP sensor for a screw to go through, looks like it needs some kind of bracket, and b) no such screw and washer came with my intake. In fact, there's a bunch of hardware missing. Anyone else having this issue, or is it just me?
Old 10-07-2016, 07:51 AM
  #220
So now, after all their colossal failures in product design and quality control, MSD has dropped the ball YET AGAIN, this time in customer service. I realized that they shorted me big time on hardware, and when I called to ask that they fix THEIR mistake, the best they could offer me was to suggest that I buy a new intake, then return the old one for a refund. Which means that I can't move forward with my build until the new intake arrives. How on earth did this company ever build a good reputation like the one they have if THIS is how they operate?
Quick Reply: Review and install guide for the MSD Atomic AirForce intake manifold.
