Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Air Intake and Exhaust Guides
- Chevrolet Camaro 2010-2015: Intake Manifold Reviews and How-to
Review and how-to
Review and install guide for the MSD Atomic AirForce intake manifold.
#65
I have mine hooked up but it just isn't running right. Has a high idle and is running terrible. Does anyone know if there's anything I need to reprogram or anything after switching from an OE throttle body to 102mm FAST one? I'm pretty sure the throttle body is causing my problem
#66
#69
That's not what I wanted to hear lol. Thanks though. Do I have to do an iac relearn procedure of some sort? I'm finding tons of completely different ones I'm not sure which one to do I have a 2002 z28. I have a Diablo in-tune tuner is this something I can straighten out with that? I just got it so I don't know much about it. I was looking at getting an hp one but I don't know a whole lot about tuning and it looked pretty advanced. Thanks for the help!
#70
Allen, you do need a tune, from a real tuner, using HPTuners or EFILive, it's not something you can get out of a handheld tuner.
Well, back to the topic at hand.
There's a reason why I don't work on the car late at night, after a long day. I checked after work yesterday and I was adjusting the throttle cable wrong. I was pulling on the plastic cable sleeve, thinking it would make it 'longer', but it actually makes the amount of cable coming out of the end shorter. So I adjusted it, and all is fine now.
I'm just waiting on an AN fitting to come and I can start the motor.
#73
Might I suggest a pair of 45* AN fittings on the front of the rails. Curve the line in front of the intake over the TB.
Glad to hear some initial thoughts about the intake. I'll never own one though. FAST 102 fits with whiskers space between it and my hood.
It looks like it will be much better for boost than the fast design. (three top center bolts)
