Head choices my last component
A little bit about my build is listed below I want to spray nitrous to the engine somewhere in the 150 to 250 range. I want it to be a street/strip car. For heads I'm looking at the
AFR 72cc
AFT 69cc
Trick flow Gen x heads
Bore. 4.030
Stroke 4.000
Compressed Gasket Thickness. 0.051in.
Intake
The FAST 102 with drive by wire throttle body
Total displacementioned 408
Crank
Engine stroke 4.000 in.
Rod journal 2.100 in.
Main journal 2.650 in.
Piston
Piston Compression distance 1.115 in
Piston head volume +8.00cc
Pin diameter 0.927 in.
Rods
Connecting rod length center 6.125
Cams
Hydraulic roller
2200-7200 basic operating rpm range
Lobe separation 113
Intake duration at 050 in 235
Exhaust duration at 050 in 243
Duration at 050 235/243
Advertised intake 285
Advertised exhaust 293
Advertised duration 285/293
AFR 72cc
AFT 69cc
Bore. 4.030
Stroke 4.000
Intake
Crank
Piston
Rods
Cams
Hydraulic roller
Lobe separation 113
Location: Coast of San Mateo County Between Pacifica & HMB
2.10 intake valve better than 2.165 for 4.030-4.060 Bore!
235 CC better than 255 CC for 408" street/strip!
Tony will also have a Nitrous/Forced Induction Exhaust Port
Option for his MMS 235 Heads, not sure at what HP/Boost
Threshold that would be most applicable/beneficial
(200HP Shot/10 PSI)? SWAG
I like the Cam Specs, I would have Kip @ CAMMOTION grind
It for you, better quality steel, gentler lobe profiles for better
Valvetrain stability/ durability, and Phenominal customer service!
