00 Z28 short im guessin need help1!!
Sry prolly wrong area, replaced starter, alternator, ignition switch, something is draining the battery witch is new aswell been an issue for a few weeks volt gauge will say 8/9 even thought i wiggled a short under dash b/c went back to 14/15 then after driving back low any advice is appreciated have had gauges go nuts also had ars n abs light come on. Also bcm? New to ls1's but love em. Electrical is my worst nightmare alternator needed replacing due to bad ps pump leaking on it so i just replaced it all doing 98000 mile run through car has headers,lid, catback, intake manifold, basic srart up but problem is new, remember reading about a wire getting pinched by column could that b it
With it off it won't allow the alternator to work properly and charge the car..
If you have someone scan your car with hptuners it might show that code p1637
I had a similar issue and it ended up being that
No lil new to ls n hate electrical do u kno color of wire or where it runs im assuming its under dash the short that is but i wiggled the harness pretty hard
