Is my throttle body to big?
my setup
iron block( ls1 bore )
stock crank
callies compstar rods
diamond nitrous pistons
stock 243 heads with dual springs
custom grind 23X 23X 600 lift cam
holley midrise intake
holley nitrous plate
is a 95mm throttle body to much for this setup? I think it will b ok i just dont want a throttle body thats an on off switch ya know i bought the hollet 95mm throttle body with low rpm taper so im hoping im good to go
stock crank
A big throttle body will be harder to tune and the last 20-40% of pedal movement will have little to no effect. I had a 102mm TB with about 420whp. At 73% on the TPS would net 101kPa all the way to redline.
It doesn't really hurt anything, you just lose resolution in the power modulation.
You'll be fine with the 95mm. The low TPS will help a lot with running as well.
