C5 Stainless Steel Headers Made In USA for Under $850 Shipped @ Hinson Motorsports
HINSON Motorsports is proud to offer the only ceramic coated stainless steel header built in the America under $850.00. The HINSON Motorsports C5 header systems are proudly built in the USA from stainless steel and then ceramic coated for lower under hood temperatures. Our ceramic coated stainless steel headers use mandrel bent 1 7/8" tubing and 3/8" flanges for a precision fit and finish.
Features
Stainless Steel Construction and High Temp Ceramic Coating
Easy installation
1 7/8" Mandrel Bent Tubing for peak exhaust flow
3" Collectors
Lower under hood temperatures than non-ceramic coated headers
Slip fit collector for easy connection to a performance X-pipe
Ceramic Coated X-pipe for reduced center console temperatures
Direct fit application for all C5's- No fabrication required.
Includes
Ceramic Coated Stainless Steel Headers
Ceramic Coated Aluminized Steel Header Extensions
Ceramic Coated Aluminized Steel X-pipe
Aluminized Steel Rear Axle Back Connection Pipes
O2 Sensor Wire Extensions (x2) $50 value
Clamps
Installed prior to ceramic coating
In stock and currently being ceramic coated. Anticipated ship date of July 27 2015.
