I'm going to have to remove my Powerbond and have read that Harbor Freight has the bolt puller set I need. Can someone tell me which set I need? There is item 69889 and 68982.
69889 probably. If it doesn't have the right bolts, just pull three bolts from the water pump and use them. They are a perfect fit to pull the powerbond.
