Question about buying new valves
I am going to get my heads ported and polished and have a valve job done and i was wondering if one kind of valve is better than the other? I can get 2.00 valves from summitt for $65 or Manley valves fro $130? Is the price difference worth it? Trying to build them on a low budget.
Thanks!
Thanks!
This is probably better in the "Gen III Internal Engine" section but hollow intake valves are the best to get as you'll get better valve control and more high RPM power with everything else the same. If you're going through the expense of porting and a valve job you'd also be a little better off getting a slightly larger valve than stock.
Thanks!
Thanks!
