Delete EVAP ?
Delete EVAP ?
So the fast 90 intake I purchased has the nipple for the EVAP plugged. My question is how hard is it to delete the EVAP system. I already have my air/egr deleted. Do I need to just put a breather on the vent tube in the fender. Also is this something that needs to be tuned out ?
I have deleted my EVAP. I capped the hard line in the engine bay and then disconnected the flexible hose from the fuel pump to the hard line in the rear of the car. Then I capped the hard line in the back too. This way the line can still be used in the future if need be. Then I extended the flexible hose from the fuel pump to the rear bumper and added a small air filter to the end of the hose. Its tucked up nice in the rear bumper and I don't have any fuel smell in the cab of the car with every thing vented out the rear. You will also have to turn off the DTC's for the EVAP system or you'll get a couple of codes pop up.
Here's what I did. Removed the line all the way back to the charcoal canister and added a breather filter on the canister.I kept it because otherwise you may get a gas smell since that's the vent for the tank. I would not cap it off it needs to breath.
