Windage tray bolt touching pickup tube, is this an issue?
I'd cut/grind/whatever, I would prefer some clearance too.
Even just running a small hacksaw down the side with it in-situ to remove some material from the but if the other options are awkward.
LS1Tech Premium Sponsor
As long as the pickup tube is able to seat in the oil pump properly it won't cause any issues. Unfortunately find replacement hardware for that really isn't an option so if you want more clearance you will need to modify the factory main stud.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Thanks for the advice. This is a mast oil pan and pickup tube. Paid $400 for this pan. It looks great and the baffle is nice for what I need but I had to cut the windage tray to bolt the pickup tube and then noticed the bolt. I'm just going to trim a little off the but and call it a day.
