Anyone use Mighty Mouse coolant overflow tank?
I saw this on their website but cant find a picture or any info at all. The only info I found was on their facebook page, which was only three pictures.
I assume the threaded part is for the bottom as coolant will flow into it as the engine heats up, then flow back into the radiator as the vacuum pulls it back in when engine cools.
I assume the small hole on top is so the coolant can go in without pressurizing the can.
My question is, is the hole on top baffled to keep the coolant from splashing out as you drive? Also, how much can the can hold? 1QT?
