Lm7 stock serpentine belt system in 72 skylark
I have a 72 skylark that I plan on dropping an lm7 in. The lm7 is out of an 01 Tahoe with stock serpentine system.
http://www.superchevy.com/how-to/eng...ped-ls-engine/
I plan on following this formula, however I noticed in the article they are using the Holley accessory drive kit.
i would like to use the stock serpentine system. In which case I take it I would need to buy the 01 Tahoe alternator?
I was wondering if anyone had a link on how to wire a late model alternator into a classic gm?
(72 skylark)
I was also wondering what If I could use the 01 Tahoe power steer steering pump, and retrofit that into the skylark? If not, what power steering pump should I use, and will it mount to the stock serpentine system?
Thank you for the time, and sorry for all the questions
(72 skylark)
