Shorty Install Pics...
Does anybody know a comprehensive document of how to install shorties? I have already purchased BBKs and did that because it's my daily driver and the smog *****. I found one site, but it was all text. My buddy's dad has done two LT1 shorty install, but obviously mine will be different. Any tips, pics or websites would be greatly appreciated. And yes, I ordered gaskets, plugs and wires also.
Originally Posted by jrp
theres not much to shorties, justs remove the old manifolds and install the shorties from the top. remove the air tube for added clearance. job should be done in less then an hour.
You are going to have to raise the car to get under it. (ramps/jack stands) Unplug all 4 O2 sensors and unscrew the front ones. The rears can stay in the pipes. Remove the Y-pipe. 2 nuts on the drivers side where it attaches to the cat and 3 nuts on the passenger side where it attaches to the manifold and the nut on the clamp where it attaches to the I-pipe. Then remove the 3 nuts that attach the drivers side cat to the manifold and remove that cat. Use lots of WD-40 on all these and still be prepared for the studs to break. Then go up top and remove the AIR tubes, coil pack brackets, plug wires, and plugs. Then remove the 6 bolts per side that hold the manifolds to the heads. Having someone under the car supporting the manifolds will help. They will come out from the bottom. A 10mm gear wrench willl help also. GM uses loc-tite on the manifold bolts so they will be hard to remove. I always clean the threads on a wire wheel and reinstall with anti-sieze. Tq the manifold bolts to 18 ft lbs. Reassemble everything in reverse order using new GM gaskets. I doubt anyone is going to get this done in less than an hour.
