Fuse Block question
Fuse Block question
hi everyone
so to make long story short i need a new fuse block the one that is on the inside of the car on the driver side. i had a short fixed the problem but melted one of the holes that holds the fuse. a new fuse wont go in the hole. don't remember what fuse it was exactly but my dash lights don't work. i have googled look on here but not able to find this piece in particular so my question is does anyone know were i can get one new or used don't matter. also wondering if the fuse block of a 97 trans am would fit my car. i have a 00 trans am A4. your help would be much helpful. thanks
You can install an inline fuse link to repair that one brunt out fuse slot. You will need to get to the back of the fuse block, cut the wires off of the burnt spot and solder in the inline fuse holder to the wires you cut from the block.
