eBay fuel rails with truck injectors
Hi guys
Will truck injectors work in these rails ? I already have an ls1 intake which I have confirmed that the injectors will fit into if I remove the plastic tip on the end. I know I'll have to shim the rail up some to compensate for the taller injector. Just wanna make sure the injector is going to fit into the rail....injectors are from a 2001 4.8. Thanks.
http://m.ebay.com/itm/310473794294
Ok. Good to know. Where would be the best place to get the Orings if needed. eBay? I wonder if that's something the local parts guy would have.
