PIC REQUEST: "New" LS6 Valley Cover Installed
I'm looking for a picture of the end result of a "new" LS6 Valley Cover swap. The new one has an internal valve and does away with the PCV hoses from what I understand. I'm installing a FAST intake and the new cover was recommended by a few people.
My concern is that 1.) I have no install directions included with the new valley cover and 2.) I have a catch can installed. I'm not sure if this will stay on or be removed with the new style valley cover
This should help: http://www.ls1howto.com/index.php?article=18
Also, you can decide if you want to run the can or not. I just Sid the swap and am trying it with no can for awhile to see how it goes.
Thank you, much appreciated.
I have an 02 C5Z with the LS6, so I do believe my PCV system is different than the LS1 already?
EDIT: I found the info I needed. My 2004 Valley cover came with a new hose to go from the cover to the manifold. The instructions you posted showed the "old" style LS6 Valley Cover which used a different hose. This confused me for some reason!
