needing some info please
Ive posted this question with no response so ill give it another try..I have a 2003 lq4 block with ls3 heads,intake im wanting to change the ps/alt bracket to locate the alt up and out like on the vetts but retain as much of the stock lq4 accessories as i can. i know i will have to change waterpumps due to TB clearance.. question is with the truck crank pulley, what car water pump can i run? and is there a stock ps/alt bracket like im talking about that i can use the truck ps and alt? or do i have to buy a ps and alt for a car? or is there a aftermarket bracket that will accept the truck alt and ps pump? also what year car? i have read where 2010 and up cameros have the same spacing but i think those brackets locate the alt low and ps pump up high and i dont want that.. ill take and advice! thanks, cameron
