Air pocket at the T-State :-(
Hy all
after i have reassembled my radiator and the T-State housing. I do have a big problem with air in the cooling.
I do have a Chevy Pickup with a LS1 swap.....no heater core (as u can see on the attached pic)
I blucked the water pump..
I do have a overflow tank
I refilled the system twice ...at the second time i jacked up the front of the car...loosening the steam ports and filled it up with fluid till the fluid came out of the steam ports. I tightened the ports up and filled the system.
Than i tried to bleed the system with a funnel assembled on the top the radiator....
After that i closed the radiator with the cap...
I restarted the engine .....after the engine was totally warmed up ..i made a temperature check with my laser pointer ....the result u can see on the pic.
The T-State was still not open ....because there has to be a big air pocket behind the T-State according to the low temperature..
At the upper radiator hose the water was already rumbling respectivly boiling..
Pls help me .....how can i get out the ******* air at the T-State ??
Thanks
Achim
Thanks
Achim
it is overheating in parking position ....but if i raise up the rpm the temperature goes down...
I guess i got the point..... i will try to use a U bend Hose for the heater core out/inlet..
So maybe the water does not move / travel around the T-State and warms it up like it should
What do u think about that solution ??
Thx
Achim
Thx
Achim
Moderator
Received 1,836 Likes
Just saw this. Yes, you need to loop the fittings together for thereafter hose
