Slave Cylinder Issue
1999 Camaro SS M6... Was in the middle of finishing a trans install and replaced the slave while down there since it was bad also and the slave cylinder won't reconnect with the master cylinder. Every slave I've replaced before has been the traditional kind with the little fingers on the inside but this new one has this black c clip thing and won't allow the male connector to go in at all. GM slave BTW but “newer" version.
Any one else dealt sort of crap before? Any help or advice?
Moderator
Received 1,836 Likes
Probably have better luck in the manual trans area. A moderator will probably move it
