Crank pulley
Crank pulley
Dose anyone sell a aftermarket crank pulley that is not a underdrive pulley. I think my stock ls1 vette pulley is wobbling and throwing my belt off I don't want to run a underdrive pulley as I don't want to slow my water pump any it already gets warm at idle sometimes I'm going to get a Katech Tensioner in hopes that will help but also want a new crank pulley all my pulleys line up and the stock crank pulley is installed with in the specs
Hinson sells the Powerbond stock diameter race pulley. I'm using this one and it's a quality piece. Spend the money for a good quality part and you're not likely to have to replace the pulley again! Hinson specializes in performance parts and they're good to deal with.
https://www.hinsonsupercars.com/p-14...-pb1117ss.aspx
If you don't mind spending the coin, and/or actually need the high rev stability, both Fluidampr, AND ATI sell their premium damper/balancer/pullies in the stock, non-underdrive sizes for our LSx 4th gen f bodies.
