weird vibrating feeling through gas pedal
The car is a 2001 M6 LS1, get a strange vibrating feeling in the gas pedal. I have a bad throwout bearing thats making some weird noise, don't think that it could cause this tho, what do you guys think? The throwout bearing is making a rattling noise at idle with the clutch out in neutral and i'm also getting an audible tick at upper rpm's that you can feel through the shifter. Lots of weird noises lots of unexplainable stuff. Let me know if you guys have any ideas. I'm getting a new clutch, throwout bearing, flywheel etc. I was told my plugs and wires look good, trans mounts were fine, no exhaust leaks. So i'm trying to get some advice. Thanks
the cables look fine at the throttlebody where they are connected. Is there a bracket further back towards the engine? My car has too many weird little noises! Ever had or heard a throwout bearing go bad? It causes all types of noise. My mechanic thinks that if the throwout bearing is bad enough it can cause a vibration not just at the shifter but throughout the entire car. I can feel a vibrating in my steering wheel, under my *** in the driver seat and the frame of the car. It isn't loud but its there. GM told me its nothing to worry about. Trans mount supposedly looked good, exhaust looked fine, nothing loose eally anywhere. I do know for sure the throwout bearing is bad so this is the only thing i can think of that would cause such a vibration. I just found it weird to feel anyhting through my gas pedal
