Wierd rattling sound from Hooker ORY....wtf????
I put in a Hooker ORY yesterday and it fit well. But on idle and just off idle (~1500rpm) it makes a tinny vibration sound on the drivers side right where the 2 pieces come together. I trimmed the heat shield and I have about 1" of room between the top of the pipe and the body. I have also installed a poly mount on the drivers side. I know it is not rubbing anywhere....I had the car on jackstands idling...I could hear the sound and I watched everything....nothing hits.....
I have stainless band clamps on the collectors (the 3" wide/2 bolt style), but I used the 1" T-Bolt style clamp where the 2 pieces of the y come together...there's really no leaks....any ideas??
It sounds like a heat shield is vibrating...very tinny...right where the 2 pieces of the y come together...
What could it be???
What could it be???
Nevermind....DUH!!!!!
I checked the metal rings as WILWAXU suggested....well, the O2 sensor on the drivers side was loose. I'm an idiot. I loosened it when I had to pull the header out but forgot to retighten it...
Since I have the JetHots, the O2s are on the inside so I didnt even see it vibrating or know that it was loose. Also, I was watching the real-time data on my Predator and the LTFTs would jump to -45% sometimes....so that explains it.
Thanks WILWAXU!!
Thanks WILWAXU!!
