Magnaflow Exhaust question
Here's something I just noticed the other day as I pulled the car out of storage to drive it on a nice day. It was a cool morning and I started the car up just fine pulled it out of the storage unit, got out to close the door and I noticed the exhaust coming from the two tips looked a little funny. The exhaust was visible as it was slightly chilly outside. Looking at the passenger side exhaust tip, the exhaust was coming straight out (high pressure) while the driver's side was noticeably weaker. Would this be a sign that I have a muffler that has degraded? This system has been on the car since 2005. Car has seen ran 2 times since I've owned it. Always garaged.
I've never noticed this before. Took it out for a drive with a few good pulls came back to put it back into storage and held my hand over the exhaust pipes and there is defiantly a difference in pressure.
Is this normal? I reached out to Magnaflow yesterday and have yet to receive a reply.
Sounds pretty normal I would say. The passenger side tail pipe has a much shorter route than the drivers side, so in theory the drivers side pipe would lose a little bit of that "pressure" per say vs the passenger side. Its more apparent on say a Borla system where the only pipe that routes the exhaust through the muffler is the one exiting on the drivers side of the car.
It's fine, the gas is just taking the path of least resistance and there is little pressure as compared to when the engine is running at higher speeds. Have someone Rev it up while you stand behind the car and you will see that it comes out both sides more evenly then. I have the same muffler on my Z28 and it does the same thing.
For what it's worth on my particular setup, opening the cutout I have installed ahead of the muffler is only worth 3HP at peak on the dyno so I'm pretty happy with it. Best flowing crossflow style muffler I'm aware of.
