Secondary air injection problem, Need Help
MY car is throwing a code 0410 for the 2ndary air system. The only thing I dont have plugged in is the little rubber line that plugs into the 2ndary air solenoid ( mounts near the driver side fuel rail). There are two hook ups on the solenoid. The bottom hook up goes to the back of the engine I think. Is that correct??? I felt around back there and there was a line already hooked up. After looking through my Fbody Platform manuals it shows a picture of a T fitting. I dont think I have one. Can anyone help? Thanks
There should be 2 lines attached to that solenoid - one of them goes a check valve in back of the block somewhere (impossible to see), the other goes to the top of the big valve thing in back that distributes the air hoses. I have the solenoid outlet for that 2nd line plugged (that would normally go to the valve), and the solenoid still hooked up electrically. No T fitting on mine (2000).
