Thunder coil relocation?
How does this thing mount to the body is it easy to take on and off if i am doing work on the car? And are the wires pre cut? Where i can just pop them on?
You have to take the wiper arms off, and the black plastic cowl, then you drill two holes in the metal cowl and the coils are on L shaped brackets that bolt on the cowl. Its not hard to do, although you may need a battery terminal puller to get the wiper arms off, some are real stubborn. The wires are precut and it is easier to work on the car, ecspecially if you need to take the valve covers off.
