Starter wire connections
I guess you have managed to sort out.
Seems that the lower large 8mm terminal post has Battery positive with 3 positive feeds out to harness.
The upper large 8mm terminal post is earthed to engine block and the small 5mm terminal post is purple starter solenoid wire.
Confirmation would be appreciated from anyone please.
Thanks Trevor
Thanks Trevor
Meee too !!
Big power to big post on starter
Big ground to block
Small purple to starter small post
small black to ground on pass side frame rail
Now I have 2 left , both red and both say "fuseable link on them "
Did you get this figured out ?? Oh yeah its a 2001 Z06 , not Fbody so I have the 5 wires
Big ground to block
