Anyone with an ASP pulley???????
What is the bolt size i need to remove the pulley. I think they are a fine thread metric. Anyone know? It should say on the instrustions....i dont have them. Thanks!
1 Post
www.ls1howto.com
The first time I had to yank my ASP I couldn't figure out the size of bolts needs I ended up just calling and asking and they went in back and looked at the tap.. I then bought a set of bolts that work on my ASP, if I wasn't 330 miles away from them I'd go try to figure out what they are but if I were you I'd just call ASP.
When I had to remove mine, I did a search and found what I was looking for in threads similar to these. Search is your friend
https://ls1tech.com/forums/showthrea...ing+asp+pulley
