TSP true duals
Old 11-24-2004, 02:59 PM
MachoCamacho's Avatar
Default TSP true duals
Does this setup come with all clamps required, including the clams used to connect it to the headers?
Old 11-24-2004, 03:48 PM
LS1Maniac's Avatar
Yep everything you need to install is there.
Old 11-24-2004, 06:01 PM
Z28Venom's Avatar
It comes with everything you need. Just make sure that you either upgrade to stainless steel bandclamps when you order the setup from TSP. Or once you get it in hand, go down to your local parts store and get some. U-clamps suck ***.
Old 11-24-2004, 09:19 PM
PatriotRedZ's Avatar
yea, whatever you do DONT use those C clamps, u clamps, whatever you may call them clamps. There seriously the WORST. Get yourself some band clamps and you will be good to go
Old 11-24-2004, 09:59 PM
Keenov's Avatar
The TSP Duals now come with band clamps, instead of the U bolts.
https://ls1tech.com/forums/showpost....36&postcount=9
