coolant hoses sucking together
Old 12-07-2004, 11:49 PM
flippincamaro's Avatar
Default coolant hoses sucking together
on my 2001 ls1 engine the coolant hoses are sucking together and the heater hoses but not all the way together. The coolant system is full but losing a little not much. What is going on with this i did a conversion put new ported heads and a cam in it now all these problems. thanks for any help
Old 12-08-2004, 12:44 AM
Gloveperson's Avatar
Is it the hose is no longer long enough?
A picture would be great.
Old 12-08-2004, 09:30 AM
Dustin Butts's Avatar
If you replaced any of the hoses with cheapy aftermarket versions you may have gotten a version that isn't stiff enough. Or you may need to find one that has a spring inside to prevent them from sucking closed.
Old 12-08-2004, 10:27 AM
98TXFBODY's Avatar
Location: Used to live in South Texas, Now in North Carolina
I bet 100 bucks you have air in the system. let the vehicle run and keep squeezing the top hose. Start it when its cold with the cap off so you can refill the level as it drops. Do this untill the vehicle reaches full operating temp.
Old 12-08-2004, 11:15 AM
weve done that twice now. The hoses used to not do that when it was in the camaro. Maybe i need to do it again. Also when we pulled the cap off there was suction not pressure on it. I will try to fill again.
Old 12-08-2004, 06:09 PM
thanks guys it needed to be filled up more and the overflow was empty
