Which Magnaflow Mufflers for True Duals
I am getting rid of the duals dumped and doing duals over the axle. Which Magnaflow mufflers is everyone using for the duals? I am thinking the Magnaflow's that are stainless steel one that are 4 X 9 and 14 inches long . Everyone just posts 4 X 9 and magnaflow has a bunch that are that size. Please do not bash my thread. I have had Borla XR-1's and know they sound good.
!LS1 11 Second Club
BTW, if you're running TD's over the axle, bullets should be fine. Mufflers + Over The Axle TD's may be too quiet.
Good luck!
The Magnaflow PN 11366 is what I'll be using on my over the axle duals in a couple of months. This muffler has a body length of 11" instead of the other Magnaflows which are usually 14", which will save me some space. The tradeoff is that it has offset/center ports on it, but I think I can work with this for the extra 3" I save in length. It is also not available in stainless.
To answer your question, I believe that most people who talk about 4x9 Magnaflows are referring to the 14" body length ones with center/center ports.
LS1Tech Co-Founder
I'm running a set of center in/out 3" inlet stainless mufflers from Magnaflow now, and I made 738rwhp thru them. Ask Tom@ls1speed.com for the part number.
