straight vs xpipe
straight vs xpipe
how much horsepower difference would it be to just run 2 straight 3 inch pipes from the headers and dumped at the axle than going with an x pipe setup dumped at the axle. say both running bullets or 1 chaber flowmasters.
would the x pipe outpower the srtaight duals?
you will gain prolly 5-10hp with an x-pipe not to mention it will sound like a v8 instead of two 4 cylinders...(well not quite a comparison but it will sound much better with the x-pipe) actually an h-pipe supposivly sounds even better than an x but won't make quite as much power...either way you get more than two straight pipes...
An X will make more power and torque across the power-band - OVER open headers, straight pipes(or header extensions), H-pipes, and Y-pipe set-ups. I've seen and tested them all over the last three and a half years.
A Dr. Gas! X that is - which is all we've tested.
where would i get an x pipe at and how much do they run? would there be a big price difference going over the axel than dumping before?
