Please help: what happened to my oil drain plug?
Hello everyone
I've been changing the oil on my '98z28 with 47,000 miles for about 3 yrs, and recently put a new, plastic washer on the drain bolt instead of the metal one which was sorta worn.
The washers
Today when I changed oil, I noticed the new, plastic washer was smashed flat and may have actually damaged the soft rubber lining inside the oil drain plug. What happened...and is this bad? Do I need a new drain plug?
Close up of the drain plug, not sure if you can see the damage
The washers
