Extending O2 Sensors
So in the shuffle on my cam swap/header install somehow all the O2 sensors were mixed up. I wan to cut them and extend them, but i just want to make sure i'm doing the work on the correct sensors. How do you identify the front sensors fron the rea, by just looking at them? I realize i could get under the car and look but its about 40 degrees and raining hard outside right now.
thanks
thanks
Is this an ORY or catted Y pipe. I mismatched my O2s and found out it does not matter, and with an ORY I have been told it is better to use the rear O2s becuase of better heater circuit. This would explain why I often get a code for driver side O2 about the heater circuit and not the passenger which was originally a rear O2.
This is for the TSP catted Y pipe with pacesetter headers. Are the front ones the ones with the darker tips? or the lighter tips? Also what length did you cut them to? 12 and 24?
Thanks
Thanks
