02 sensors stuck??
02 sensors stuck??
I am installing headers and got to the point of removing my 02 sensors from the old exhaust. For some reason the sensors on the drivers side will not come out. I got them loose and moved them about 1 turn and then they just locked up, Like there is something stuck on them.
The passenger side ones came out just fine.
I searched and it appears I can use the ones from the passenger side for my header bungs. ( I will get the rear sensors tuned out).
Just wondering if there is a trick to remove these or if this has happened to anyone else???
I would kind of like to save them as new ones ain't cheap.
Thanks!
Thanks!
wd40 is your friend, use it. Mine were hard to get out as well, just need more force. Get someone else to give it a shot, or to help hold it if you already took the old exhaust off.
