connections on back of LS6 intake?
Old 01-20-2005, 04:11 AM
ABNRNGR (Aka Dean)'s Avatar
Default connections on back of LS6 intake?
what are the two lines that connect to the back used for? one is electrical and one is a plastic vacum looking line?
Old 01-20-2005, 05:40 AM
TT-TECH Veteran
Inspector12's Avatar
Well actually there are three you have one electrical connection for the MAP sensor you have one going to the brake booster and there is a small vacum line for the A/C. Note A/C will not work with out it.
Old 01-20-2005, 08:24 AM
thanks
Old 01-20-2005, 10:19 AM
Xsta Z 28's Avatar
Be very carefull the the brake vacuum line, it can snag the oil pressure sensor and break it off. Or just unplug it . . .
Old 01-22-2005, 06:07 AM
Viper's Avatar
Perhaps this will help:
Quick Reply: connections on back of LS6 intake?
