Cutout Causing rattling?
i recently bought an jegs exhaust c/o i placed it in the I pipe under the rear passenger side and it sounds great but i have a problem with rattling ....it happenes when i let off the gas and coast in gear or revving and letting off ....has any body had the same problem did u do anything about it ?????
i dont have a c/o but i have nothing past the y pipe and mine makes the change jump in my console, its aggrevating, i would like an answer to this too if there is one
its not rattlin. Its the sound of the colder outside air being sucked into the pipe when you let off the gas. The noise you hear is caused by the cold and hot air meeting causing a noise that sounds like rattling. Mine does this too and it is pretty much normal.
