How did you guys hold your motor in place during K-member install
Old 01-30-2005, 09:28 AM
Kurtomac's Avatar
Default How did you guys hold your motor in place during K-member install
Got a PA racing Mild steel Tubular k member on the way just wondering how you guys held your motor in place during the install, a friend said something about placing a board under the oil pan and using a floor jack but i dont like the idea of my engine being held up by my oil pan, lets hear how you did it and if you did it again how you would have done it knowing what you know now, thanks, Kurt
Old 01-30-2005, 10:21 AM
smokeum99ta's Avatar
I went and got some longer bolts that are the same size as the header bolts and used a cherry picker [engine lift]w/ a piece of chain.use big washers[the ones that are big around w/ small hole] so that it can catch the chain.hope this helps
Old 01-30-2005, 10:23 AM
Droptopws6's Avatar
What?
Old 01-30-2005, 11:05 AM
WILWAXU's Avatar
A freind used a strut tower brace and a strap.
I was lucky enough to use a lift.. just put some muffler jacks under motor.
Old 01-30-2005, 11:20 AM
TT-TECH Veteran
Inspector12's Avatar
Jack stands under the car and a jack with a piece of wood under the oil pan works for me when options are limited. Of course the strut tower brace ia always an option if it is a strong one like the BMR or SLP I don't know if I would trust the Hotckis one it is made of aluminum and I woudn't want to see anyone get hurt. The engin hoist is always a good option. Good luck and be careful.
Old 01-30-2005, 11:57 AM
LS1Tech Sponsor
Slowhawk's Avatar
Same here.Jack with a piece of wood under the oil pan
Old 01-30-2005, 12:02 PM
frcefed98's Avatar
Another "jack with piece of wood under the oil pan" person here. BMR K-Member tho.
Old 01-30-2005, 12:07 PM
Kurtomac's Avatar
ok sounds like ill do the jack with a 2x8 under the oil pan......ill be doing it on a lift
Old 01-30-2005, 12:29 PM
SPANKY LS1's Avatar
Can also run a piece of tubing from shock tower to shock tower and hold the engine up with a chain or a strap.
Shawn
Old 01-30-2005, 01:15 PM
cyphur's Avatar
Shawn
I think thats what John was talking about with the strut tower brace.
Old 01-30-2005, 07:29 PM
SPANKY LS1's Avatar
Yeah yeah yeah, thats what I get for skimming through quickly....
Shawn
Old 01-30-2005, 09:33 PM
That's what she said...
TheBlurLS1's Avatar
those bolts are a *bit* small!
i used a jack and some wood under the oil pan when changing my motor mounts.
