Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Steering & Suspension Guides
- Camaro How to Change Power Steering Fluid<br>Step by step instructions for do-it-yourself repairs.
flushing power steering fluid
How do I flush the power steering fluid? I'm pretty sure it doesn't have a drain plug but i have noticed that it foams. Every time I checked it foams up. Please help? and what fluid should I put in?
If it is foaming up you are getting air into the system, you may have a leak somewhere. The factory pumps are junk, as are the replacement GM ones. If you have problems with your pump get a Turn One Pump.
As far as flushing the fluid you can drain some out with a turkey baster and replace with fresh, running the engine in between. You will need to do this a few times to be effective.
The other way is to disconnect the return line and have the pump suck fresh fluid from a bottle while the other end of the hose runs into a pan while the engine is running. This can be a mess but works much better.
Run synthetic power steering fluid, whatever you can find.
Good Luck!!
Good Luck!!
You can buy the pump from Lingenfelter, or direct from Turn One.
This thread details my former problems.
https://ls1tech.com/forums/showthrea...power+steering
