Exhaust Leak!
Old 02-23-2005, 10:44 PM
newpew02's Avatar
Default Exhaust Leak!
Installed my QTPs and ORY and they sound great, but...Where the I-pipe inserts into the y-pipe it is a fairly loose seal. The clamp I had there before wasn't big enough to fit over the Y-pipe side. I was wanting to know what kind of exhaust clamp would be best for this loose fitting to get the best seal.
Old 02-24-2005, 09:16 AM
Keenov's Avatar
A band clamp.
Old 02-24-2005, 11:10 AM
ls1fbod's Avatar
or weld it
Old 02-24-2005, 11:16 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I'd get one of them fancy MIG welder clamps...you know, the ones that throw all the sparks when you put them on. Guaranteed to not leak (provided the guy knows how to weld).
Old 02-24-2005, 04:28 PM
newpew02's Avatar
Don't wanna weld in case I have to adjust it
Old 02-24-2005, 05:53 PM
CRL 01 SS's Avatar
I got my i-pipe/cutout welded to the end of my y-pipe, then I had a flange welded between my i-pipe/cutout and my catback. The y-pipe has band clamps at the collectors. All I have to do to remove the y-pipe is loosen the band clamps and unbolt the flange. You may want to do something like that.
