Weiand intake install questions.
Old 03-15-2005, 10:16 AM
Drivn2Fast's Avatar
Default Weiand intake install questions.
ok so I tried searching but with no luck so here it goes.
I just recently bought a used weiand intake off of this board that did not have any bolts, gaskets, etc.
I have bought the gasket kit from summit and I have all of the pressure tap connections, does anyone know what else I need? I was reading a thread that said something about needing the bolts that come with it, is this true? Also my car is a 98, do I need any special pcv connections or anything I am not thinking of. Thanks in advance.
Dave
...ok what is needed to put a ls6 intake on a 1998 car??
Old 03-15-2005, 03:18 PM
Drivn2Fast's Avatar
...ttt someone has got ot know.
Old 03-15-2005, 04:31 PM
Q
Q's Avatar
Are you still running the EGR? If not, you'll need a block off plate/plug for the top of the holley. You'll also need the correct head coolant lines and back two coolant plugs. Check your email. I have more info sent to you.
